Aller au contenu principal
Asus Chromebook C523N Speaker Replacement
Ce dont vous avez besoin
  1. Asus Chromebook C523N Speaker Replacement, Back Cover: étape 1, image 1 de 2 Asus Chromebook C523N Speaker Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Speaker Replacement: étape 2, image 1 de 2 Asus Chromebook C523N Speaker Replacement: étape 2, image 2 de 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Speaker Replacement: étape 3, image 1 de 2 Asus Chromebook C523N Speaker Replacement: étape 3, image 2 de 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Speaker Replacement, Speaker: étape 4, image 1 de 3 Asus Chromebook C523N Speaker Replacement, Speaker: étape 4, image 2 de 3 Asus Chromebook C523N Speaker Replacement, Speaker: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Speaker Replacement: étape 5, image 1 de 3 Asus Chromebook C523N Speaker Replacement: étape 5, image 2 de 3 Asus Chromebook C523N Speaker Replacement: étape 5, image 3 de 3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Speaker Replacement: étape 6, image 1 de 2 Asus Chromebook C523N Speaker Replacement: étape 6, image 2 de 2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Speaker Replacement: étape 7, image 1 de 1
    • Gently grab both speakers and lift them from the Chromebook to remove.
2 autres ont terminé cette réparation.
Aaron Hogan
Membre depuis le 10/15/19
682 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 18
Total : 682
