Aller au contenu principal
Asus EEE PC 1000HD Keyboard Replacement
Ce dont vous avez besoin
  1. Asus EEE PC 1000HD Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
  2. Asus EEE PC 1000HD Keyboard Replacement: étape 2, image 1 de 2 Asus EEE PC 1000HD Keyboard Replacement: étape 2, image 2 de 2
    • Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
    • Hold one end of the keyboard down to make prying easier.
    • Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
  3. Asus EEE PC 1000HD Keyboard Replacement: étape 3, image 1 de 1
    • Once you lift the keyboard, there will be a metal tab that connects the keyboard to the metal panel below.
    • Detach this metal tab slowly.
  4. Asus EEE PC 1000HD Keyboard Replacement: étape 4, image 1 de 1
    • The keyboard should be fully detached.
    • With your new replacement keyboard, insert the metal tab back into the metal panel. Press gently on the keyboard to lock it into place.
    • There should be a few clicking noises as the new keyboard latches onto the metal board.
Emily Gao
Membre depuis le 10/17/17
101 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team S2-G6, Weedon Fall 2017 Membre de l'équipe UC Santa Barbara, Team S2-G6, Weedon Fall 2017
UCSB-WEEDON-F17S2G6
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 553
