Aller au contenu principal
Asus Eee PC 1005PEB Battery Replacement
  1. Asus Eee PC 1005PEB Battery Replacement, Battery: étape 1, image 1 de 1
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Asus Eee PC 1005PEB Battery Replacement: étape 2, image 1 de 1
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Asus Eee PC 1005PEB Battery Replacement: étape 3, image 1 de 2 Asus Eee PC 1005PEB Battery Replacement: étape 3, image 2 de 2
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Asus Eee PC 1005PEB Battery Replacement: étape 4, image 1 de 1
    • Using both hands, pull the battery horizontally away from the laptop.
2 autres ont terminé cette réparation.
Aaron Arenas
Membre depuis le 04/20/14
751 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 13-32, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 1,566
