Aller au contenu principal
Asus Eee PC 1015PN motherboard dismantling (English)
Ce dont vous avez besoin
  1. Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: étape 1, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: étape 1, image 2 de 2
    • To remove the battery, unlock the marked tabs.
  2. Asus Eee PC 1015PN  motherboard dismantling (English): étape 2, image 1 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 2, image 2 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 2, image 3 de 3
    • To remove the memory, lift the plastic tab covering the memory screw with a small slot head screwdriver.
  3. Asus Eee PC 1015PN  motherboard dismantling (English): étape 3, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 3, image 2 de 2
    • Lift the plastic cover and remove the SO-DIMM module.
  4. Asus Eee PC 1015PN  motherboard dismantling (English): étape 4, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 4, image 2 de 2
    • Remove the dummy SD-Card
  5. Asus Eee PC 1015PN  motherboard dismantling (English): étape 5, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 5, image 2 de 2
    • Unscrew 4 screws that are located in the battery compartment. Once removed, plastic tabs need to be removed on the upper part.
  6. Asus Eee PC 1015PN  motherboard dismantling (English): étape 6, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 6, image 2 de 2
    • With an extraction tool, separate the keyboard chassis from the netbook, it has many tabs.
  7. Asus Eee PC 1015PN  motherboard dismantling (English): étape 7, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 7, image 2 de 2
    • While separating the keyboard chassis, be careful with the keyboard connector. To remove it, simply slide the plastic retainer to be able to free it.
  8. Asus Eee PC 1015PN  motherboard dismantling (English): étape 8, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 8, image 2 de 2
    • Unscrew the marked screws. One of those screws is behind a warranty sticker.
  9. Asus Eee PC 1015PN  motherboard dismantling (English): étape 9, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 9, image 2 de 2
    • Disconnect the mouse connector. The connector has a white plastic tab that disconnects the connector.
  10. Asus Eee PC 1015PN  motherboard dismantling (English): étape 10, image 1 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 10, image 2 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 10, image 3 de 3
    • With a flat screwdriver, release two plastic tabs ( 1 on each side), and with pressure in the front, release the chassis.
  11. Asus Eee PC 1015PN  motherboard dismantling (English): étape 11, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 11, image 2 de 2
    • To disconnect the hard drive, two connectors need to be removed, pay attention to the connectors sides, the one on the left in marked as MB and the right is marked as IO.
  12. Asus Eee PC 1015PN  motherboard dismantling (English): étape 12, image 1 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 12, image 2 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 12, image 3 de 3
    • Remove the screws, and slide the hard drive free.
  13. Asus Eee PC 1015PN  motherboard dismantling (English): étape 13, image 1 de 1
    • Disconnect the motherboard connector and the IO plate.
  14. Asus Eee PC 1015PN  motherboard dismantling (English): étape 14, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 14, image 2 de 2
    • Remove the fan connector, the BIOS battery and the upper connector.
  15. Asus Eee PC 1015PN  motherboard dismantling (English): étape 15, image 1 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 15, image 2 de 3 Asus Eee PC 1015PN  motherboard dismantling (English): étape 15, image 3 de 3
    • Remove the plate screws and release the screen connector.
  16. Asus Eee PC 1015PN  motherboard dismantling (English): étape 16, image 1 de 2 Asus Eee PC 1015PN  motherboard dismantling (English): étape 16, image 2 de 2
    • Remove the motherboard from the chassis, and disconnect a connector that is glued.
6 autres ont terminé cette réparation.
Merci à ces traducteurs :
es en
100%
DeZom nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jorge Casal Lopez
Membre depuis le 05/09/13
313 Réputation
1 tutoriel rédigé
2 commentaires
Joder la que hay que liar para cambiar el disco duro.
Rafael Belmonte - Réponse
Thank you for the guide
ilcaccillo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 58
Total : 13,742
