Aller au contenu principal
Asus Eee PC 1201HAB Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: étape 1, image 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: étape 1, image 2 de 2
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: étape 2, image 1 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: étape 2, image 2 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: étape 2, image 3 de 3
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: étape 5, image 1 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: étape 5, image 2 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: étape 5, image 3 de 3
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: étape 6, image 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement: étape 6, image 2 de 2
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: étape 7, image 1 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: étape 7, image 2 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: étape 7, image 3 de 3
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: étape 8, image 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement: étape 8, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: étape 9, image 1 de 1
    • Remove and replace the hard drive.
Katherine Chan
Membre depuis le 10/22/18
353 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team S7-G3, Lore Fall 2018 Membre de l'équipe UC Davis, Team S7-G3, Lore Fall 2018
UCD-LORE-F18S7G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 21
Total : 865
