Introduction
If your Asus Eee PC 900 LCD display screen is damaged, experiencing pixel issues, or is dim in a bright background, use this guide to replace your display screen.
Prior to making this repair, it is important to confirm that the replacement itself is necessary. Check to make sure that no other solutions are viable. For problems such as pixel issues, inverter issues, or not being able to see color, a full replacement may be necessary.
This guide requires you to remove the battery, keyboard, top cover, and LCD display screen from your Asus Eee PC 900. Some steps require the use of a spudger.
Before beginning, make sure to completely power down the device and disconnect from any external power source.
Ce dont vous avez besoin
Slide the battery's locking tabs from the locked position to unlocked positions.
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
15 autres ont terminé cette réparation.
2 commentaires
Perfect guide, thank you.
