Ce dont vous avez besoin
Slide the battery's locking tabs from the locked position to unlocked positions.
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
8 autres ont terminé cette réparation.
2 commentaires
If you have a 900HD, there are only 8 screws in step 7. The ninth "screw" -- the second from the right in the bottom row, to the right of the blue ribbon -- is under the hard drive. You have to remove the hard drive cover on the bottom, remove the hard drive, then remove the screw there.
how much the replacement of top and back cover of this laptop?
