Aller au contenu principal
Asus F554LA-WS52 Disc Drive
Ce dont vous avez besoin
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: étape 1, image 1 de 2 Asus F554LA-WS52 Disc Drive, Disc Drive: étape 1, image 2 de 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: étape 2, image 1 de 3 Asus F554LA-WS52 Disc Drive: étape 2, image 2 de 3 Asus F554LA-WS52 Disc Drive: étape 2, image 3 de 3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: étape 3, image 1 de 2 Asus F554LA-WS52 Disc Drive: étape 3, image 2 de 2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: étape 4, image 1 de 2 Asus F554LA-WS52 Disc Drive: étape 4, image 2 de 2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: étape 5, image 1 de 3 Asus F554LA-WS52 Disc Drive: étape 5, image 2 de 3 Asus F554LA-WS52 Disc Drive: étape 5, image 3 de 3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
2 autres ont terminé cette réparation.
Aaron Ratliff
Membre depuis le 10/09/18
527 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G2, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 8
Total : 557
