Aller au contenu principal
Asus F554LA-WS52 Touchpad Replacement
Ce dont vous avez besoin
  1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: étape 1, image 1 de 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: étape 1, image 2 de 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: étape 1, image 3 de 3
    • Make sure your notebook device is unplugged and turned off before opening it up.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Touchpad Replacement: étape 2, image 1 de 3 Asus F554LA-WS52 Touchpad Replacement: étape 2, image 2 de 3 Asus F554LA-WS52 Touchpad Replacement: étape 2, image 3 de 3
    • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
  3. Asus F554LA-WS52 Touchpad Replacement: étape 3, image 1 de 1
    • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
  4. Asus F554LA-WS52 Touchpad Replacement: étape 4, image 1 de 3 Asus F554LA-WS52 Touchpad Replacement: étape 4, image 2 de 3 Asus F554LA-WS52 Touchpad Replacement: étape 4, image 3 de 3
    • Once you've removed the plastic cover, flip it over.
    • Next, carefully remove the tape from the bottom side of your touch pad.
  5. Asus F554LA-WS52 Touchpad Replacement: étape 5, image 1 de 1
    • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
  6. Asus F554LA-WS52 Touchpad Replacement: étape 6, image 1 de 3 Asus F554LA-WS52 Touchpad Replacement: étape 6, image 2 de 3 Asus F554LA-WS52 Touchpad Replacement: étape 6, image 3 de 3
    • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
    • Replace touch pad.
Clint Eagle
Membre depuis le 10/09/18
300 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G2, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 10
Total : 224
