Aller au contenu principal
Asus F555LA-AB31 Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: étape 2, image 1 de 3 Asus F555LA-AB31 Hard Drive Replacement: étape 2, image 2 de 3 Asus F555LA-AB31 Hard Drive Replacement: étape 2, image 3 de 3
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: étape 3, image 1 de 3 Asus F555LA-AB31 Hard Drive Replacement: étape 3, image 2 de 3 Asus F555LA-AB31 Hard Drive Replacement: étape 3, image 3 de 3
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: étape 4, image 1 de 1
    • Disconnect the ZIF connector and lift the hard drive out of the space.
JC Chavez
Membre depuis le 04/04/19
202 Réputation
2 tutoriels rédigés
Un commentaire
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 29
Total : 1,698
