Introduction
The screen is important for viewing content on your laptop. A malfunctioning screen can affect your workflow negatively. Be sure to use a screen that fits the dimensions of the laptop (13.3" WXGA).
Ce dont vous avez besoin
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
Lay the laptop right side up.
Rotate laptop 90 degrees towards you, so the empty battery compartment is visible.
Insert a finger nail, or the flat end of a spudger, into the slit between the bezel and the back cover of the laptop.
Gently pry the bezel towards you to remove it from the back panel of the laptop.
Continue to pry around the perimeter of the laptop until the entire bezel has been removed.
With a pair of tweezers, grab on to the white connector at the bottom of the screen. Gently, but firmly, pull the connector to the right to to remove it.
Repeat this process with the white connector attached to the webcam above the screen.
Partially remove the adhesive securing the black tap to the screen so that the adhesive is only attached to the black tab.
Pull the black tab gently, towards the back of the laptop to remove it from the screen.
