Aller au contenu principal
Asus G750JW-BBI7N05 Display Replacement
Ce dont vous avez besoin
  1. Asus G750JW-BBI7N05 Display Replacement, Battery: étape 1, image 1 de 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Display Replacement: étape 2, image 1 de 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Display Replacement: étape 3, image 1 de 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Display Replacement, Display: étape 4, image 1 de 1
    • Place your laptop in the upright and open position.
  5. Asus G750JW-BBI7N05 Display Replacement: étape 5, image 1 de 1
    • Remove the four 4mm Phillips #00 screws from the four corners of the display.
  6. Asus G750JW-BBI7N05 Display Replacement: étape 6, image 1 de 1
    • Gently pry the front bezel away from the screen and back bezel with an opening tool.
    • The bezel is the outside plastic frame surrounding the screen.
    • You will feel and hear the bezel "unsnap" as you move the pry tool around the entire display.
  7. Asus G750JW-BBI7N05 Display Replacement: étape 7, image 1 de 1
    • As you work, be mindful of other components that surround the screen, like the WiFi antenna, Bluetooth, webcam, and microphone.
    • Remove the six 6mm Phillips #00 screws across the top of the screen and the four 6mm Phillips #00 screws at the bottom of the screen.
  8. Asus G750JW-BBI7N05 Display Replacement: étape 8, image 1 de 1
    • With the screws removed, the metal bracket surrounding the screen will feel loose.
    • Remove the top bracket by pulling upwards on the tabs.
  9. Asus G750JW-BBI7N05 Display Replacement: étape 9, image 1 de 1
    • Remove the four 3mm Phillips #00 screws from the sides of the screen.
  10. Asus G750JW-BBI7N05 Display Replacement: étape 10, image 1 de 1
    • With the screen free, tilt it gently forward to reveal the display data cable.
    • Unplug the display data cable by peeling off the clear sticker covering its connector, then pulling this connector out of its socket.
    • Make sure to only peel off the sticker that covers the display data cable connector.
  11. Asus G750JW-BBI7N05 Display Replacement: étape 11, image 1 de 2 Asus G750JW-BBI7N05 Display Replacement: étape 11, image 2 de 2
    • Remove the two side brackets from the sides of the screen by removing the six 3mm Phillips #00 screws attaching it. There are three screws on either side of the screen.
5 autres ont terminé cette réparation.
Sandy Jewell
Membre depuis le 10/05/17
342 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 2,198
