Aller au contenu principal
Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
Ce dont vous avez besoin
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: étape 1, image 1 de 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 2, image 1 de 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 3, image 1 de 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: étape 4, image 1 de 2 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: étape 4, image 2 de 2
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 5, image 1 de 1
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 6, image 1 de 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 6, image 2 de 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 6, image 3 de 3
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 7, image 1 de 1
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: étape 8, image 1 de 1
    • Lift the speaker to remove it.
3 autres ont terminé cette réparation.
Stephanie Asling
Membre depuis le 10/05/17
424 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 750
