Aller au contenu principal
Asus G75VW-BHI7N07 Subwoofer Replacement
Ce dont vous avez besoin
  1. Asus G75VW-BHI7N07 Subwoofer Replacement, Subwoofer: étape 1, image 1 de 3 Asus G75VW-BHI7N07 Subwoofer Replacement, Subwoofer: étape 1, image 2 de 3 Asus G75VW-BHI7N07 Subwoofer Replacement, Subwoofer: étape 1, image 3 de 3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Subwoofer Replacement: étape 2, image 1 de 3 Asus G75VW-BHI7N07 Subwoofer Replacement: étape 2, image 2 de 3 Asus G75VW-BHI7N07 Subwoofer Replacement: étape 2, image 3 de 3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Subwoofer Replacement: étape 3, image 1 de 2 Asus G75VW-BHI7N07 Subwoofer Replacement: étape 3, image 2 de 2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Subwoofer Replacement: étape 4, image 1 de 2 Asus G75VW-BHI7N07 Subwoofer Replacement: étape 4, image 2 de 2
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands to get to the subwoofer.
  5. Asus G75VW-BHI7N07 Subwoofer Replacement: étape 5, image 1 de 3 Asus G75VW-BHI7N07 Subwoofer Replacement: étape 5, image 2 de 3 Asus G75VW-BHI7N07 Subwoofer Replacement: étape 5, image 3 de 3
    • Remove the 4 screws (6 mm) around the subwoofer with the flex extension J0 Phillips-head screwdriver.
    • Lift the subwoofer out using your hands.
    • Move back the film covering wiring using the opening tool to reveal a white-and-black wire.
  6. Asus G75VW-BHI7N07 Subwoofer Replacement: étape 6, image 1 de 1
    • Use the small spudger to unplug the white-and-black wire.
Joy
Membre depuis le 09/08/17
437 Réputation
4 tutoriels rédigés
Équipe
Un commentaire
Hi! I have no sound from me left and right speakers. Subwoofer is working ok. Do you happen to know how to repair the left and right speaers? Thanks in advance.
Michael
Micha el Darcy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 782
