Aller au contenu principal
Asus K50IJ Charging Port Replacement
Ce dont vous avez besoin
  1. Asus K50IJ Charging Port Replacement, Battery: étape 1, image 1 de 1
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
  2. Asus K50IJ Charging Port Replacement: étape 2, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 2, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 2, image 3 de 3
    • Lift the exposed lip and remove the battery cover.
  3. Asus K50IJ Charging Port Replacement: étape 3, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 3, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 3, image 3 de 3
    • Press the tabs on the battery and lift them. The battery should come out easily.
  4. Asus K50IJ Charging Port Replacement, Fan: étape 4, image 1 de 3 Asus K50IJ Charging Port Replacement, Fan: étape 4, image 2 de 3 Asus K50IJ Charging Port Replacement, Fan: étape 4, image 3 de 3
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
  5. Asus K50IJ Charging Port Replacement: étape 5, image 1 de 1
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
  6. Asus K50IJ Charging Port Replacement: étape 6, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 6, image 2 de 2
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
  7. Asus K50IJ Charging Port Replacement: étape 7, image 1 de 1
    • Unplug the wire cable attached to the fan by pulling it out .
  8. Asus K50IJ Charging Port Replacement: étape 8, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 8, image 2 de 2
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
  9. Asus K50IJ Charging Port Replacement, Charging Port: étape 9, image 1 de 1
    • Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
  10. Asus K50IJ Charging Port Replacement: étape 10, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 10, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 10, image 3 de 3
    • Using the PH1 screwdriver, remove the four .75 mm screws from the copper heat sync. They will be labeled 1-4.
    • Pull the copper heat sync out of the laptop.
  11. Asus K50IJ Charging Port Replacement: étape 11, image 1 de 1
    • Using the PH1 screwdriver, remove four .75 mm screws from the driver, located in the bottom-right corner of the laptop.
  12. Asus K50IJ Charging Port Replacement: étape 12, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 12, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 12, image 3 de 3
    • Pull on the black tab on the driver to slide the driver back, and lift the driver out of the laptop.
  13. Asus K50IJ Charging Port Replacement: étape 13, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 13, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 13, image 3 de 3
    • Using the PH1 screwdriver, remove the five .5 mm screws from the SD card reader, located in the bottom-middle corner of the laptop.
    • Slide the SD card reader away and out.
  14. Asus K50IJ Charging Port Replacement: étape 14, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 14, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 14, image 3 de 3
    • Detach the white and black wires from the Wi-Fi card, located in the central area of the laptop.
  15. Asus K50IJ Charging Port Replacement: étape 15, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 15, image 2 de 2
    • Using the PH 1 screwdriver, remove the two .25 mm screws from the Wi-Fi card.
  16. Asus K50IJ Charging Port Replacement: étape 16, image 1 de 1
    • Slide the Wi-Fi card out of its slot to remove.
  17. Asus K50IJ Charging Port Replacement: étape 17, image 1 de 1
    • Using the PH1mm screwdriver, remove one .5 mm screw from the disk drive, located inthe top-right corner of the laptop.
  18. Asus K50IJ Charging Port Replacement: étape 18, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 18, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 18, image 3 de 3
    • Slide the disc drive out of its slot.
  19. Asus K50IJ Charging Port Replacement: étape 19, image 1 de 1
    • Using the PH 1 screwdriver, remove the two .5 mm screws from the RAM drive.
  20. Asus K50IJ Charging Port Replacement: étape 20, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 20, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 20, image 3 de 3
    • Slide and lift the RAMdrive out of its port.
  21. Asus K50IJ Charging Port Replacement: étape 21, image 1 de 1
    • Using the PH1 screwdriver, remove the .75 mm screw from the plastic housing corner, located in the bottom-right corner of the laptop.
  22. Asus K50IJ Charging Port Replacement: étape 22, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 22, image 2 de 2
    • Unplug the black cable from the central area of the laptop.
  23. Asus K50IJ Charging Port Replacement: étape 23, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 23, image 2 de 2
    • Unplug the wire cable in the central area of the laptop.
  24. Asus K50IJ Charging Port Replacement: étape 24, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 24, image 2 de 2
    • Unplug the wire and black cables on the motherboard, located in the upper-left corner of the laptop.
  25. Asus K50IJ Charging Port Replacement: étape 25, image 1 de 1
    • Using the PH1 screwdriver, unscrew the two .75 mm screws from the top-left corner of the motherboard.
  26. Asus K50IJ Charging Port Replacement: étape 26, image 1 de 1
    • Using the PH 1 screwdriver, remove the .75 cm screw from the top-middle section of the motherboard.
  27. Asus K50IJ Charging Port Replacement: étape 27, image 1 de 1
    • Using the PH1 screwdriver, remove the .75 mm screw from the top-middle corner of the motherboard.
  28. Asus K50IJ Charging Port Replacement: étape 28, image 1 de 1
    • Using the PH1 screwdriver, remove the three .75 mm screws from the bottom corner of the motherboard.
  29. Asus K50IJ Charging Port Replacement: étape 29, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 29, image 2 de 2
    • There is a ribbon cable connected to the back of the motherboard. Be careful not to break the ribbon cable.
    • Slide the motherboard to the right and lift it up, but do not pull it completely out.
  30. Asus K50IJ Charging Port Replacement: étape 30, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 30, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 30, image 3 de 3
    • Gently unplug the ribbon cable from the underside of the motherboard.
  31. Asus K50IJ Charging Port Replacement: étape 31, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 31, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 31, image 3 de 3
    • The ribbon cable that was plugged into the motherboard is attached to the keyboard. Be sure not to damage it.
    • Use the metal spudger or opening tool across the top edge of the keyboard to pop it out.
  32. Asus K50IJ Charging Port Replacement: étape 32, image 1 de 2 Asus K50IJ Charging Port Replacement: étape 32, image 2 de 2
    • Use the metal spudger or opening tool to pop out the plastic hinge covers.
  33. Asus K50IJ Charging Port Replacement: étape 33, image 1 de 1
    • Use the PH1 screwdriver to remove the .75 mm screws from the hinges. Each hinge has one screw.
  34. Asus K50IJ Charging Port Replacement: étape 34, image 1 de 1
    • Be careful not to damage the cables that are attached to the screen frame. Be sure to pull them through the laptop carefully.
    • The screen should separate from the rest of the laptop.
  35. Asus K50IJ Charging Port Replacement: étape 35, image 1 de 1
    • Using the PH1 screwdriver, remove the .75 mm screw from the bottom-middle section was previously covering.
  36. Asus K50IJ Charging Port Replacement: étape 36, image 1 de 1
    • Using the PH 1 screwdriver, remove the .75 cm screw from the bottom-middle section where the keyboard was previously covering.
  37. Asus K50IJ Charging Port Replacement: étape 37, image 1 de 1
    • Lift the front cover off of the laptop.
  38. Asus K50IJ Charging Port Replacement: étape 38, image 1 de 3 Asus K50IJ Charging Port Replacement: étape 38, image 2 de 3 Asus K50IJ Charging Port Replacement: étape 38, image 3 de 3
    • Flip the laptop back over. The charging port will be located in the top-right corner.
Andrew Anderson
Membre depuis le 09/27/17
265 Réputation
2 tutoriels rédigés
Un commentaire
Cool really nice guide. If I could rate I would give it a 5 but I got one question. How tf do I put it back together now?
Merlin Fornels - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 40
Total : 4,156
