Aller au contenu principal
Asus K50IJ Fan Replacement
Ce dont vous avez besoin
  1. Asus K50IJ Fan Replacement, Battery: étape 1, image 1 de 1
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
  2. Asus K50IJ Fan Replacement: étape 2, image 1 de 3 Asus K50IJ Fan Replacement: étape 2, image 2 de 3 Asus K50IJ Fan Replacement: étape 2, image 3 de 3
    • Lift the exposed lip and remove the battery cover.
  3. Asus K50IJ Fan Replacement: étape 3, image 1 de 3 Asus K50IJ Fan Replacement: étape 3, image 2 de 3 Asus K50IJ Fan Replacement: étape 3, image 3 de 3
    • Press the tabs on the battery and lift them. The battery should come out easily.
  4. Asus K50IJ Fan Replacement, Fan: étape 4, image 1 de 3 Asus K50IJ Fan Replacement, Fan: étape 4, image 2 de 3 Asus K50IJ Fan Replacement, Fan: étape 4, image 3 de 3
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
  5. Asus K50IJ Fan Replacement: étape 5, image 1 de 1
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
  6. Asus K50IJ Fan Replacement: étape 6, image 1 de 2 Asus K50IJ Fan Replacement: étape 6, image 2 de 2
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
  7. Asus K50IJ Fan Replacement: étape 7, image 1 de 1
    • Unplug the wire cable attached to the fan by pulling it out .
  8. Asus K50IJ Fan Replacement: étape 8, image 1 de 2 Asus K50IJ Fan Replacement: étape 8, image 2 de 2
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
Kyle Starbird
Membre depuis le 09/27/17
147 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 881
