Aller au contenu principal
Asus K53E-BBR3 Keyboard Replacement
Ce dont vous avez besoin
  1. Asus K53E-BBR3 Keyboard Replacement, Battery: étape 1, image 1 de 3 Asus K53E-BBR3 Keyboard Replacement, Battery: étape 1, image 2 de 3 Asus K53E-BBR3 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: étape 2, image 1 de 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: étape 2, image 2 de 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: étape 2, image 3 de 3
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  3. Asus K53E-BBR3 Keyboard Replacement: étape 3, image 1 de 1
    • Gently pull the ribbon cable to the right and out of its port.
Liza Sousa
Membre depuis le 10/17/16
355 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-1, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 771
