Aller au contenu principal
Asus K53E-BBR3 RAM Replacement
Ce dont vous avez besoin
  1. Asus K53E-BBR3 RAM Replacement, Battery: étape 1, image 1 de 3 Asus K53E-BBR3 RAM Replacement, Battery: étape 1, image 2 de 3 Asus K53E-BBR3 RAM Replacement, Battery: étape 1, image 3 de 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 RAM Replacement, Back Panel: étape 2, image 1 de 1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 RAM Replacement: étape 3, image 1 de 1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 RAM Replacement, RAM: étape 4, image 1 de 1
    • After sliding down the back panel you will see three individual compartments with different components. The one to the far right is the RAM.
  5. Asus K53E-BBR3 RAM Replacement: étape 5, image 1 de 3 Asus K53E-BBR3 RAM Replacement: étape 5, image 2 de 3 Asus K53E-BBR3 RAM Replacement: étape 5, image 3 de 3
    • To remove the RAM stick, locate the silver tabs holding the stick in place.
    • Move the silver tabs so that the detents are no longer holding the RAM in place. Once you've done this, the RAM will pop up and out.
Bradley Anastacio
Membre depuis le 10/18/16
213 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-1, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 656
