Aller au contenu principal
Asus K53E-BBR3 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Asus K53E-BBR3 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 3 Asus K53E-BBR3 Wi-Fi Card Replacement, Battery: étape 1, image 2 de 3 Asus K53E-BBR3 Wi-Fi Card Replacement, Battery: étape 1, image 3 de 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Wi-Fi Card Replacement, Back Panel: étape 2, image 1 de 1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 1
    • Disconnect the wires by pulling them up.
  5. Asus K53E-BBR3 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Unscrew the two 5mm Phillips #1 screws.
  6. Asus K53E-BBR3 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Lift up the Wi-Fi card and remove it.
Liza Sousa
Membre depuis le 10/17/16
355 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-1, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 20
Total : 689
