Aller au contenu principal
Asus K53E-BBR7 Keyboard Replacement
Ce dont vous avez besoin
  1. Asus K53E-BBR7 Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Asus K53E-BBR7 Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Asus K53E-BBR7 Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Turn off the device.
    • Disconnect the charging cable if applicable.
    • Push the two locking mechanisms away from the center of the device and slowly remove the battery.
  2. Asus K53E-BBR7 Keyboard Replacement: étape 2, image 1 de 3 Asus K53E-BBR7 Keyboard Replacement: étape 2, image 2 de 3 Asus K53E-BBR7 Keyboard Replacement: étape 2, image 3 de 3
    • Insert the blue prying tool into each of the five tabs at the top of your keyboard, moving from the outer edge inward. Use the blue prying tool to separate the keyboard from the palm rest.
    • Use your hand to gently pull the keyboard away from the laptop.
  3. Asus K53E-BBR7 Keyboard Replacement: étape 3, image 1 de 2 Asus K53E-BBR7 Keyboard Replacement: étape 3, image 2 de 2
    • As the keyboard comes loose, gently lift the board up so the bottom is exposed
    • The base of the keyboard will be tethered to the device by a piece of silver cable ribbon. Tearing this piece away from the keyboard quickly can damage the device.
    • Use your fingers to gently disconnect the silver cable ribbon from the palm rest.
4 autres ont terminé cette réparation.
Graham Rumbaugh
Membre depuis le 10/28/16
173 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team 1-3, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-3, Rose Fall 2016
UWT-ROSE-F16S1G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 1,450
