Introduction
If your Asus K55VD is having problems reading DVDs, not playing audio or videos properly, or DVD programs won't install properly then it may be experiencing a faulty optical disk drive which needs to be replaced.
Ce dont vous avez besoin
Étape 1 Battery
Attention : l'étape 1 est issue d'un tutoriel marqué comme en cours.
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
Un commentaire
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
