Aller au contenu principal
Asus K55a-si50301p Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus K55a-si50301p Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Hard Drive Replacement: étape 2, image 1 de 1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Hard Drive Replacement: étape 3, image 1 de 1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Hard Drive Replacement, Lower Back Panel: étape 4, image 1 de 1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Hard Drive Replacement: étape 5, image 1 de 1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Hard Drive Replacement: étape 6, image 1 de 1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Hard Drive Replacement, Hard Drive: étape 7, image 1 de 2 Asus K55a-si50301p Hard Drive Replacement, Hard Drive: étape 7, image 2 de 2
    • Remove the (3) screws that hold the hard drive to the case.
  8. Asus K55a-si50301p Hard Drive Replacement: étape 8, image 1 de 2 Asus K55a-si50301p Hard Drive Replacement: étape 8, image 2 de 2
    • Disconnect the SATA link from the hard drive by pulling back on the grey connector.
  9. Asus K55a-si50301p Hard Drive Replacement: étape 9, image 1 de 1
    • Remove the two screws from each side of the hard drive tray.
    • Replace the hard drive with a new 2.5" hard drive or solid state drive.
4 autres ont terminé cette réparation.
Christian Bocanegra
Membre depuis le 02/12/19
273 Réputation
2 tutoriels rédigés
Un commentaire
So the link you give for the replacement hard drive is for a 3.5 inch drive instead of a 2.5 inch drive
sweal - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 18
Total : 1,110
