Aller au contenu principal
Asus K55a-si50301p RAM Replacement
Ce dont vous avez besoin
  1. Asus K55a-si50301p RAM Replacement, Battery: étape 1, image 1 de 1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p RAM Replacement: étape 2, image 1 de 1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p RAM Replacement: étape 3, image 1 de 1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p RAM Replacement, Lower Back Panel: étape 4, image 1 de 1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p RAM Replacement: étape 5, image 1 de 1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p RAM Replacement: étape 6, image 1 de 1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p RAM Replacement, RAM: étape 7, image 1 de 1
    • Press slot pins outwards with gentle force.
  8. Asus K55a-si50301p RAM Replacement: étape 8, image 1 de 1
    • After the RAM stick pops up, pull it towards you to gently remove it.
2 autres ont terminé cette réparation.
Bryce Myers
Membre depuis le 02/12/19
136 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 17
Total : 456
