Aller au contenu principal
Asus MeMO Pad 7 ME176C Speaker Replacement
Ce dont vous avez besoin
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: étape 1, image 1 de 2 Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    iFixit Opening Tool
    $1.99
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: étape 2, image 1 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: étape 2, image 2 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: étape 2, image 3 de 3
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: étape 3, image 1 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: étape 3, image 2 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: étape 3, image 3 de 3
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: étape 4, image 1 de 1
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: étape 5, image 1 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: étape 5, image 2 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: étape 5, image 3 de 3
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: étape 6, image 1 de 1
    • Now you can attach a new speaker!
Maxime
Membre depuis le 09/26/17
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S6-G3, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 258
