Aller au contenu principal
Asus MeMO Pad HD 7 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus MeMO Pad HD 7  Motherboard Replacement, Remove Rear Panel: étape 1, image 1 de 3 Asus MeMO Pad HD 7  Motherboard Replacement, Remove Rear Panel: étape 1, image 2 de 3 Asus MeMO Pad HD 7  Motherboard Replacement, Remove Rear Panel: étape 1, image 3 de 3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7  Motherboard Replacement: étape 2, image 1 de 1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7  Motherboard Replacement: étape 3, image 1 de 1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7  Motherboard Replacement, Remove Battery: étape 4, image 1 de 3 Asus MeMO Pad HD 7  Motherboard Replacement, Remove Battery: étape 4, image 2 de 3 Asus MeMO Pad HD 7  Motherboard Replacement, Remove Battery: étape 4, image 3 de 3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
  5. Asus MeMO Pad HD 7  Motherboard Replacement, Motherboard: étape 5, image 1 de 1
    • Locate the speaker wires to the left side of the battery. Remove the connector by pulling up gently or prying with a tool if you can not get a good grip.
  6. Asus MeMO Pad HD 7  Motherboard Replacement: étape 6, image 1 de 1
    • Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the motherboard.
  7. Asus MeMO Pad HD 7  Motherboard Replacement: étape 7, image 1 de 1
    • Remove the data ribbon for the motherboard which is located on the right side of the board. It has a flat top on the connector. Remove it by using a spudger to pry it straight up.
    • Locate the volume and power button connector on the left side of the mother board. Disconnect the ZIF connector by flipping the latch on the connector up and sliding the data cable directly out.
  8. Asus MeMO Pad HD 7  Motherboard Replacement: étape 8, image 1 de 1
    • Unscrew two #000 Philips 1.5 mm screws on the right side of the motherboard.
    • Unscrew 3 #000 Philips 2 mm screws from the left and center of the board.
    • The board will now lift straight up.
10 autres ont terminé cette réparation.
Julien Daigle
Membre depuis le 01/20/15
1 235 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 11-3, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 11-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G3
4 membres
5 tutoriels rédigés
2 commentaires
The camera cable is clipped in too. Be careful. The connector is under yellow tape on the other side of the board.
tsolorio - Réponse
Where can I buy the data ribbon cable for the motherboard? Mine is badly damaged and I really want to bring my old tablet back to life.
JStar334 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 8,502
