Introduction
This guide will show you how to replace the logic board of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide requires some skill and you must be careful when following directions. This guide will help you with other replacement guides for the Asus PadFone S.
Place your thumb in the charging port and pry the back cover off of the phone.
  • Place your thumb in the charging port and pry the back cover off of the phone.
Ajouter un commentaire
Remove all screws using the T5 Torx screwdriver Lift the back panel off the phone.
  • Remove all screws using the T5 Torx screwdriver
  • Lift the back panel off the phone.
Disconnect the battery from the logic board using tweezers Using the plastic opening tools, lift the battery up from its slot
  • Disconnect the battery from the logic board using tweezers
  • Using the plastic opening tools, lift the battery up from its slot
  • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
Disconnect all wires and bands from microphone, SIM card port and side bottons Disconnect all wires and bands from microphone, SIM card port and side bottons Disconnect all wires and bands from microphone, SIM card port and side bottons
  • Disconnect all wires and bands from microphone, SIM card port and side bottons
Disconnect remaining band from the logic board Lift the logic board out of the phone Lift the logic board out of the phone
  • Disconnect remaining band from the logic board
  • Lift the logic board out of the phone
2 autre(s) ont terminé cette réparation.
Greg Betsold
Membre depuis le 23/10/2014
89 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 membres
5 tutoriels rédigés
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 3,111
