Introduction
This guide will show you how to remove the side buttons of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide will make it easy to replace a broken side buttons to get your phone working again.
Place your thumb in the charging port and pry off the back cover.
  • Place your thumb in the charging port and pry off the back cover.
Ajouter un commentaire
Remove all screws using a T5 Torx screwdriver.
  • Remove all screws using a T5 Torx screwdriver.
  • After removing screws, lift the back panel off of the phone.
  • Turn the phone so the left edge is facing you.
  • Using your fingers, gently pull up on the buttons to remove them from the phone.
Greg Betsold
Membre depuis le 23/10/2014
89 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 membres
5 tutoriels rédigés
My Asus Padfone S Side
Buttons Got Error ..
Its Press It But No Peanuts ( Klik Sound ) Inside :(
How To Fix It ??
By Ndra - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 842
