Aller au contenu principal
Asus Padfone 2 A68 Sub Cables Replacement
Ce dont vous avez besoin
  1. Asus Padfone 2 A68 Sub Cables Replacement, Power Down Device: étape 1, image 1 de 1
    • Hold down the power button.
  2. Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: étape 2, image 1 de 3 Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: étape 2, image 2 de 3 Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: étape 2, image 3 de 3
    • Use plastic opening tools to pry off the cover of the phone.
  3. Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: étape 3, image 1 de 3 Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: étape 3, image 2 de 3 Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: étape 4, image 1 de 2 Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: étape 4, image 2 de 2
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 A68 Sub Cables Replacement, Removal of A68 Sub Cables: étape 5, image 1 de 1
    • Use tweezers to unplug the sub cables from the circuit board and housing.
  6. Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: étape 6, image 1 de 2 Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: étape 6, image 2 de 2
    • Plug in new sub cables to the circuit board and housing.
Erica
Membre depuis le 09/25/14
467 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-4, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 membres
7 tutoriels rédigés
Un commentaire
Boas. Onde posso comprar este cabo?
rsebastiao - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,236
