Ce dont vous avez besoin
Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
Six 9.6 mm screws
Four 4.6 mm screws
Push metal bracket away from battery connector.
Use a spudger to push the battery connection straight up.
Disconnect the Wifi/Bluetooth RF cables from the wireless card.
Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
Pull straight up to disconnect the SATA combo cable from the motherboard.
Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
Four 3.7 mm screws
3 autres ont terminé cette réparation.
2 commentaires de tutoriel
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
I just wanted to disconnect the battery to reset the BIOS. Old machine. But when I did step 3 (Push metal bracket away from battery connector) the metal bracket touched something on the board and created a small spark. The machine would no longer power up. I must have fried the power supply. If I had to do it over, I would have put tape on the board near the metal bracket so it couldn't touch anything. Also, trying to get that bracket back on was super difficult.
