Aller au contenu principal
Asus Q325U Battery Replacement
Ce dont vous avez besoin
  1. Asus Q325U Battery Replacement, Back Panel: étape 1, image 1 de 3 Asus Q325U Battery Replacement, Back Panel: étape 1, image 2 de 3 Asus Q325U Battery Replacement, Back Panel: étape 1, image 3 de 3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Battery Replacement: étape 2, image 1 de 3 Asus Q325U Battery Replacement: étape 2, image 2 de 3 Asus Q325U Battery Replacement: étape 2, image 3 de 3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Battery Replacement, Battery: étape 3, image 1 de 2 Asus Q325U Battery Replacement, Battery: étape 3, image 2 de 2
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  4. Asus Q325U Battery Replacement: étape 4, image 1 de 2 Asus Q325U Battery Replacement: étape 4, image 2 de 2
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
  5. Asus Q325U Battery Replacement: étape 5, image 1 de 2 Asus Q325U Battery Replacement: étape 5, image 2 de 2
    • Lift the battery out from the laptop.
4 autres ont terminé cette réparation.
Flo Costa
Membre depuis le 01/24/19
235 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S19-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 membres
6 tutoriels rédigés
7 commentaires
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Dan Goldman - Réponse
Would recommend the screw size be ad to the guide please.
John Walshaw - Réponse
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
Michelle N - Réponse
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
Steve Kumar - Réponse
the battery shown here is not the same for the Q325U, different battery connectors.
Joshua Delgado - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 36
Total : 4,819
