Aller au contenu principal
Asus Q325U Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Q325U Motherboard Replacement, Back Panel: étape 1, image 1 de 3 Asus Q325U Motherboard Replacement, Back Panel: étape 1, image 2 de 3 Asus Q325U Motherboard Replacement, Back Panel: étape 1, image 3 de 3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Motherboard Replacement: étape 2, image 1 de 3 Asus Q325U Motherboard Replacement: étape 2, image 2 de 3 Asus Q325U Motherboard Replacement: étape 2, image 3 de 3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Motherboard Replacement, SSD: étape 3, image 1 de 2 Asus Q325U Motherboard Replacement, SSD: étape 3, image 2 de 2
    • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
  4. Asus Q325U Motherboard Replacement: étape 4, image 1 de 2 Asus Q325U Motherboard Replacement: étape 4, image 2 de 2
    • Carefully slide and lift the SSD to remove it.
  5. Asus Q325U Motherboard Replacement, Battery: étape 5, image 1 de 2 Asus Q325U Motherboard Replacement, Battery: étape 5, image 2 de 2
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  6. Asus Q325U Motherboard Replacement: étape 6, image 1 de 2 Asus Q325U Motherboard Replacement: étape 6, image 2 de 2
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
  7. Asus Q325U Motherboard Replacement: étape 7, image 1 de 2 Asus Q325U Motherboard Replacement: étape 7, image 2 de 2
    • Lift the battery out from the laptop.
  8. Asus Q325U Motherboard Replacement, Copper Plate: étape 8, image 1 de 2 Asus Q325U Motherboard Replacement, Copper Plate: étape 8, image 2 de 2
    • Remove the six 3mm screws using a Phillips #00.
  9. Asus Q325U Motherboard Replacement: étape 9, image 1 de 2 Asus Q325U Motherboard Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
  10. Asus Q325U Motherboard Replacement: étape 10, image 1 de 2 Asus Q325U Motherboard Replacement: étape 10, image 2 de 2
    • On the other side of the plate, remove the tape.
  11. Asus Q325U Motherboard Replacement, CPU Fan: étape 11, image 1 de 2 Asus Q325U Motherboard Replacement, CPU Fan: étape 11, image 2 de 2
    • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
  12. Asus Q325U Motherboard Replacement: étape 12, image 1 de 1
    • Detach the black wire and plug shown using a tweezer.
  13. Asus Q325U Motherboard Replacement: étape 13, image 1 de 1
    • Grab CPU fan by its edge and gently pull upwards to remove.
  14. Asus Q325U Motherboard Replacement, Motherboard: étape 14, image 1 de 2 Asus Q325U Motherboard Replacement, Motherboard: étape 14, image 2 de 2
    Outil utilisé dans cette étape :
    Halberd Spudger
    $2.99
    J'achète
    • Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
  15. Asus Q325U Motherboard Replacement: étape 15, image 1 de 3 Asus Q325U Motherboard Replacement: étape 15, image 2 de 3 Asus Q325U Motherboard Replacement: étape 15, image 3 de 3
    J'achète
    • Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
    • Remove the orange connector by pulling with tweezers.
  16. Asus Q325U Motherboard Replacement: étape 16, image 1 de 3 Asus Q325U Motherboard Replacement: étape 16, image 2 de 3 Asus Q325U Motherboard Replacement: étape 16, image 3 de 3
    • Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
    • Remove the touch pad connector by pulling with tweezers.
  17. Asus Q325U Motherboard Replacement: étape 17, image 1 de 3 Asus Q325U Motherboard Replacement: étape 17, image 2 de 3 Asus Q325U Motherboard Replacement: étape 17, image 3 de 3
    • Lift the black tab on the long white plastic piece of the thick blue band.
    • Remove the thick blue band by pulling.
  18. Asus Q325U Motherboard Replacement: étape 18, image 1 de 3 Asus Q325U Motherboard Replacement: étape 18, image 2 de 3 Asus Q325U Motherboard Replacement: étape 18, image 3 de 3
    • Remove the two Phillips #000 screws on the metal connector above the thick orange band.
    • Lift up the thick orange band.
  19. Asus Q325U Motherboard Replacement: étape 19, image 1 de 3 Asus Q325U Motherboard Replacement: étape 19, image 2 de 3 Asus Q325U Motherboard Replacement: étape 19, image 3 de 3
    • Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
  20. Asus Q325U Motherboard Replacement: étape 20, image 1 de 2 Asus Q325U Motherboard Replacement: étape 20, image 2 de 2
    • Lift up the black hinge of the connector using a plastic opening tool.
    • Remove the connector using a tweezer.
  21. Asus Q325U Motherboard Replacement: étape 21, image 1 de 3 Asus Q325U Motherboard Replacement: étape 21, image 2 de 3 Asus Q325U Motherboard Replacement: étape 21, image 3 de 3
    • Pull up the tap of the biggest connector using your fingers.
    • Lift the gold hinge using a plastic opening tool.
    • Lift the connector up with your fingers to remove.
  22. Asus Q325U Motherboard Replacement: étape 22, image 1 de 2 Asus Q325U Motherboard Replacement: étape 22, image 2 de 2
    • Remove the four 4.8 mm screws using a Phillips #00 screwdriver.
  23. Asus Q325U Motherboard Replacement: étape 23, image 1 de 2 Asus Q325U Motherboard Replacement: étape 23, image 2 de 2
    • Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
  24. Asus Q325U Motherboard Replacement: étape 24, image 1 de 2 Asus Q325U Motherboard Replacement: étape 24, image 2 de 2
    • Pull the motherboard away from the corner to remove.
Miriam Miller
Membre depuis le 01/24/19
678 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-1, Johann Winter 2023 Membre de l'équipe Cal Poly, Team 2-1, Johann Winter 2023
CPSU-JOHANN-W23S2G1
4 membres
5 tutoriels rédigés
Un commentaire
Can you help me identify which of those is the webcam conector? I hava a faulty webcam and my guess is that it is a physical conection problem.
pgmolin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 19
Total : 881
