Aller au contenu principal
Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: étape 2, image 1 de 1
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: étape 3, image 1 de 1
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: étape 4, image 1 de 1
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
cameron
Membre depuis le 02/15/17
319 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 12-5, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 497
