Aller au contenu principal
Asus Q501LA-BBI6T03 Battery Replacement
Ce dont vous avez besoin
  1. Asus Q501LA-BBI6T03 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Battery Replacement: étape 2, image 1 de 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Battery Replacement: étape 3, image 1 de 2 Asus Q501LA-BBI6T03 Battery Replacement: étape 3, image 2 de 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Battery Replacement, Battery: étape 4, image 1 de 1
    • Remove the five silver 4mm Phillips #0 screws holding the battery to the laptop.
  5. Asus Q501LA-BBI6T03 Battery Replacement: étape 5, image 1 de 1
    • Using the spudger, carefully remove the power cable connecting the battery to the rest of the laptop.
  6. Asus Q501LA-BBI6T03 Battery Replacement: étape 6, image 1 de 1
    • Once the screws and cable are removed, carefully lift the battery from the laptop.
7 autres ont terminé cette réparation.
Kyle Nagao
Membre depuis le 01/25/17
366 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-1, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 21
Total : 5,570
