Aller au contenu principal
Asus Q501LA-BBI6T03 Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus Q501LA-BBI6T03 Hard Drive Replacement, Back Panel: étape 1, image 1 de 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Hard Drive Replacement: étape 2, image 1 de 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Hard Drive Replacement: étape 3, image 1 de 2 Asus Q501LA-BBI6T03 Hard Drive Replacement: étape 3, image 2 de 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the four 3mm Phillips #0 screws shown.
  5. Asus Q501LA-BBI6T03 Hard Drive Replacement: étape 5, image 1 de 1
    • Take hard drive out of the port by sliding the component to the left.
    • There is only one way it comes out of the connector. If it seems too hard to push out you are probably going the wrong way.
  6. Asus Q501LA-BBI6T03 Hard Drive Replacement: étape 6, image 1 de 1
    • Once the hard drive has been removed from the connector, use your thumb to get under and lift the hard drive out.
4 autres ont terminé cette réparation.
Aodhan Arias
Membre depuis le 01/25/17
288 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-1, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 13
Total : 2,662
