Aller au contenu principal
Asus Q502LA-BSI5T14 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 2, image 1 de 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 3, image 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: étape 3, image 2 de 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 4, image 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: étape 4, image 2 de 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: étape 5, image 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 6, image 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: étape 6, image 2 de 2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 9, image 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: étape 9, image 2 de 2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: étape 10, image 1 de 1
    • Gently lift the motherboard out and away from the laptop.
3 autres ont terminé cette réparation.
Mary Kounelas
Membre depuis le 09/25/17
715 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S4-G1, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 11
Total : 1,592
