Aller au contenu principal
Asus Q503UA Battery Replacement
Ce dont vous avez besoin
  1. Asus Q503UA Battery Replacement, Battery Replacement: étape 1, image 1 de 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery Replacement: étape 2, image 1 de 2 Asus Q503UA Battery Replacement: étape 2, image 2 de 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery Replacement: étape 3, image 1 de 3 Asus Q503UA Battery Replacement: étape 3, image 2 de 3 Asus Q503UA Battery Replacement: étape 3, image 3 de 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
To reinstall the back cover, follow these instructions in reverse order.
5 autres ont terminé cette réparation.
Gilberto Coronado
Membre depuis le 08/26/19
145 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G4, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 467
