Aller au contenu principal
Asus Q505UA-BI5T7 Battery Replacement
Ce dont vous avez besoin
  1. Asus Q505UA-BI5T7 Battery Replacement, Back Cover: étape 1, image 1 de 2 Asus Q505UA-BI5T7 Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Battery Replacement: étape 2, image 1 de 3 Asus Q505UA-BI5T7 Battery Replacement: étape 2, image 2 de 3 Asus Q505UA-BI5T7 Battery Replacement: étape 2, image 3 de 3
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Battery Replacement: étape 3, image 1 de 1
    • Gently remove the cover and lift it off of the back of the device.
  4. Asus Q505UA-BI5T7 Battery Replacement, Battery: étape 4, image 1 de 2 Asus Q505UA-BI5T7 Battery Replacement, Battery: étape 4, image 2 de 2
    • Make sure your device is turned off. Remove the 5 mm screws on each respective side of the battery by twisting counter-clockwise with a #0 Phillips screwdriver.
  5. Asus Q505UA-BI5T7 Battery Replacement: étape 5, image 1 de 3 Asus Q505UA-BI5T7 Battery Replacement: étape 5, image 2 de 3 Asus Q505UA-BI5T7 Battery Replacement: étape 5, image 3 de 3
    • Use a plastic opening tool to gently pry off the connected panel.
  6. Asus Q505UA-BI5T7 Battery Replacement: étape 6, image 1 de 1
    • Gently lift the battery.
Cooper Madison-Dawson
Membre depuis le 10/02/23
217 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 31
Total : 151
