Aller au contenu principal
Asus Q524U Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Q524U Motherboard Replacement, Back Panel: étape 1, image 1 de 2 Asus Q524U Motherboard Replacement, Back Panel: étape 1, image 2 de 2
    • Remove ten 3 mm screws using a Phillips #0 screwdriver.
  2. Asus Q524U Motherboard Replacement: étape 2, image 1 de 1
    • Lift up the back panel and set it to the side.
  3. Asus Q524U Motherboard Replacement, Battery: étape 3, image 1 de 2 Asus Q524U Motherboard Replacement, Battery: étape 3, image 2 de 2
    • Using your fingers, grip onto both sides of the wire harness and push it upwards.
  4. Asus Q524U Motherboard Replacement: étape 4, image 1 de 2 Asus Q524U Motherboard Replacement: étape 4, image 2 de 2
    • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
  5. Asus Q524U Motherboard Replacement: étape 5, image 1 de 3 Asus Q524U Motherboard Replacement: étape 5, image 2 de 3 Asus Q524U Motherboard Replacement: étape 5, image 3 de 3
    • Tilt the small black tab up which will allow the blue tape to be slid out.
  6. Asus Q524U Motherboard Replacement: étape 6, image 1 de 1
    • Simply lift the battery up and out of its holding area.
  7. Asus Q524U Motherboard Replacement, Fan Assembly: étape 7, image 1 de 1
    • Remove the four 3 mm screws holding the fan in place using a Phillips #0 screwdriver.
  8. Asus Q524U Motherboard Replacement: étape 8, image 1 de 2 Asus Q524U Motherboard Replacement: étape 8, image 2 de 2
    • Remove five 3 mm screws holding the heat sink in place using a Phillips #0 screwdriver.
  9. Asus Q524U Motherboard Replacement: étape 9, image 1 de 3 Asus Q524U Motherboard Replacement: étape 9, image 2 de 3 Asus Q524U Motherboard Replacement: étape 9, image 3 de 3
    • Pull up fan connector tab by using the plastic handle.
  10. Asus Q524U Motherboard Replacement: étape 10, image 1 de 2 Asus Q524U Motherboard Replacement: étape 10, image 2 de 2
    • Unwind the cable wrapped around the fan casing.
  11. Asus Q524U Motherboard Replacement: étape 11, image 1 de 1
    • Disconnect the small cable from the fan.
  12. Asus Q524U Motherboard Replacement: étape 12, image 1 de 1
    • After all screws and cables are unsecured, lift the fan assembly out of the laptop.
  13. Asus Q524U Motherboard Replacement, Wi-Fi Card: étape 13, image 1 de 2 Asus Q524U Motherboard Replacement, Wi-Fi Card: étape 13, image 2 de 2
    • Disconnect the black and white wires by pulling them up.
  14. Asus Q524U Motherboard Replacement: étape 14, image 1 de 2 Asus Q524U Motherboard Replacement: étape 14, image 2 de 2
    • Unscrew the single 3 mm screw using a Phillips #0 screwdriver.
  15. Asus Q524U Motherboard Replacement: étape 15, image 1 de 2 Asus Q524U Motherboard Replacement: étape 15, image 2 de 2
    • Slide the Wi-Fi card out of its slot.
  16. Asus Q524U Motherboard Replacement, Motherboard: étape 16, image 1 de 2 Asus Q524U Motherboard Replacement, Motherboard: étape 16, image 2 de 2
    • Remove the seven screws attached to the motherboard using a Phillips #0 screwdriver.
  17. Asus Q524U Motherboard Replacement: étape 17, image 1 de 3 Asus Q524U Motherboard Replacement: étape 17, image 2 de 3 Asus Q524U Motherboard Replacement: étape 17, image 3 de 3
    • Using your finger flip the tab holding this light blue ribbon cable and move it out of the way.
  18. Asus Q524U Motherboard Replacement: étape 18, image 1 de 2 Asus Q524U Motherboard Replacement: étape 18, image 2 de 2
    • Using your fingers lift this tab up and pull out the blue ribbon cable.
  19. Asus Q524U Motherboard Replacement: étape 19, image 1 de 3 Asus Q524U Motherboard Replacement: étape 19, image 2 de 3 Asus Q524U Motherboard Replacement: étape 19, image 3 de 3
    • Flip up the orange tab beneath the Wi-Fi card and pull out the wire.
  20. Asus Q524U Motherboard Replacement: étape 20, image 1 de 3 Asus Q524U Motherboard Replacement: étape 20, image 2 de 3 Asus Q524U Motherboard Replacement: étape 20, image 3 de 3
    • Using your fingers, disconnect this wire harness by pushing it out from both sides.
  21. Asus Q524U Motherboard Replacement: étape 21, image 1 de 2 Asus Q524U Motherboard Replacement: étape 21, image 2 de 2
    • With your fingers, pull this tab up to disconnect the wire from the motherboard.
    • With this tab out of the way you can now pull the motherboard out.
Kevin Nguyen
Membre depuis le 03/08/23
151 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 241
