Aller au contenu principal
Asus Q525U Back Cover Replacement
Ce dont vous avez besoin
  1. Asus Q525U Back Cover Replacement, Back Cover: étape 1, image 1 de 3 Asus Q525U Back Cover Replacement, Back Cover: étape 1, image 2 de 3 Asus Q525U Back Cover Replacement, Back Cover: étape 1, image 3 de 3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Back Cover Replacement: étape 2, image 1 de 3 Asus Q525U Back Cover Replacement: étape 2, image 2 de 3 Asus Q525U Back Cover Replacement: étape 2, image 3 de 3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Back Cover Replacement: étape 3, image 1 de 3 Asus Q525U Back Cover Replacement: étape 3, image 2 de 3 Asus Q525U Back Cover Replacement: étape 3, image 3 de 3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
Stewart Crandall
Membre depuis le 02/22/22
550 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 2-5, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 12
Total : 573
