Introduction
If your laptop frequently overheats, it may be time to clean or replace your fan. Access the Central Processing Unit (CPU) fan with this guide. If your fan is dusty, you may be able to used compressed air to clean it out and get it back into working order but either way, this guide will help you remove the fan from the device.
Since the battery and CPU fan share a screw in order to secure both components, you will need to remove both components in order to replace a faulty CPU fan. Careful attention must be made to correctly disconnect the difficult-to-access cord which runs along the side of the CPU fan.
Before beginning this repair, be sure to power off your laptop and disconnect from the power adapter.
Ce dont vous avez besoin
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
The battery of the device is outlined in red.
Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
Outil utilisé dans cette étape :Halberd Spudger$2.99
Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
Use the Halberd spudger to carefully disconnect the bundled slide connector that connects the CPU fan to the motherboard.
