Aller au contenu principal
Asus Q550LF-BBI7T07 Disc Drive Replacement
Ce dont vous avez besoin
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: étape 1, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: étape 1, image 2 de 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 2, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 2, image 2 de 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 3, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 4, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 4, image 2 de 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: étape 5, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: étape 5, image 2 de 2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 6, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 6, image 2 de 2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: étape 7, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: étape 7, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 8, image 1 de 1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 9, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 9, image 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 10, image 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: étape 10, image 2 de 2
    • Slowly slide out the disc drive, keeping it level, to remove it.
Chance Woudenberg
Membre depuis le 10/02/18
673 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 16
Total : 425
