Aller au contenu principal
Asus Q550LF-BBI7T07 Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Q550LF-BBI7T07 Motherboard Replacement, Battery: étape 1, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 2, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 2, image 2 de 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 3, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 4, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 4, image 2 de 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Motherboard Replacement, Hard Drive: étape 5, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement, Hard Drive: étape 5, image 2 de 2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 6, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 6, image 2 de 2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Motherboard Replacement, Disc Drive: étape 7, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement, Disc Drive: étape 7, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 8, image 1 de 1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 9, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 9, image 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 10, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 10, image 2 de 2
    • Slowly slide out the disc drive, keeping it level, to remove it.
  11. Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: étape 11, image 1 de 3 Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: étape 11, image 2 de 3 Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: étape 11, image 3 de 3
    • Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
  12. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 12, image 1 de 1
    • Pull out first RAM chip.
  13. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 13, image 1 de 1
    • Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
  14. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 14, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 14, image 2 de 2
    • Pull out second RAM chip.
  15. Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: étape 15, image 1 de 3 Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: étape 15, image 2 de 3 Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: étape 15, image 3 de 3
    • Remove the ten screws surrounding the fan and cooling assembly using a Phillips #0 screwdriver.
    • Remove the two silver 5 mm Phillips head screws that hold the fan in place.
    • Remove the eight black 4 mm Phillips head screws that hold the fan in place.
  16. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 16, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 16, image 2 de 2
    • Disconnect the multi-colored cable that attaches the fan to the motherboard.
    • Pick the fan up to remove it from the motherboard.
  17. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 17, image 1 de 3 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 17, image 2 de 3 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 17, image 3 de 3
    • Use the Phillips #0 Screwdriver to remove the four screws on the edge of the motherboard;
    • Remove the one black 3 mm screw.
    • Remove the three silver 5 mm screws.
  18. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 18, image 1 de 1
    • Use the Phillips #0 Screwdriver to remove the remaining four black 7 mm screws on the edge of the motherboard.
  19. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 19, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 19, image 2 de 2
    • Disconnect the five cables that are attached to the motherboard by gently pulling them.
    • Disconnect the four remaining cables attached to the motherboard by lifting the tabs and gently pulling them out.
  20. Asus Q550LF-BBI7T07 Motherboard Replacement: étape 20, image 1 de 2 Asus Q550LF-BBI7T07 Motherboard Replacement: étape 20, image 2 de 2
    • Use the metal spudger to pry and lift the silver hinge that is connected to the motherboard to release it.
    • Pull the motherboard out by hand in a counterclockwise motion to remove it.
Chance Woudenberg
Membre depuis le 10/02/18
673 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 21
Total : 1,452
