Aller au contenu principal
Asus Q550LF-BBI7T07 RAM Replacement
Ce dont vous avez besoin
  1. Asus Q550LF-BBI7T07 RAM Replacement, Battery: étape 1, image 1 de 2 Asus Q550LF-BBI7T07 RAM Replacement, Battery: étape 1, image 2 de 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 RAM Replacement: étape 2, image 1 de 2 Asus Q550LF-BBI7T07 RAM Replacement: étape 2, image 2 de 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 RAM Replacement: étape 3, image 1 de 2 Asus Q550LF-BBI7T07 RAM Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 RAM Replacement: étape 4, image 1 de 2 Asus Q550LF-BBI7T07 RAM Replacement: étape 4, image 2 de 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 RAM Replacement, RAM: étape 5, image 1 de 3 Asus Q550LF-BBI7T07 RAM Replacement, RAM: étape 5, image 2 de 3 Asus Q550LF-BBI7T07 RAM Replacement, RAM: étape 5, image 3 de 3
    • Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
  6. Asus Q550LF-BBI7T07 RAM Replacement: étape 6, image 1 de 1
    • Pull out first RAM chip.
  7. Asus Q550LF-BBI7T07 RAM Replacement: étape 7, image 1 de 1
    • Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
  8. Asus Q550LF-BBI7T07 RAM Replacement: étape 8, image 1 de 2 Asus Q550LF-BBI7T07 RAM Replacement: étape 8, image 2 de 2
    • Pull out second RAM chip.
4 autres ont terminé cette réparation.
Chance Woudenberg
Membre depuis le 10/02/18
673 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 14
Total : 613
