Aller au contenu principal
Asus Q551L Battery Replacement
Ce dont vous avez besoin
  1. Asus Q551L Battery Replacement, Back Panel: étape 1, image 1 de 2 Asus Q551L Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Battery Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Battery Replacement, Battery: étape 3, image 1 de 2 Asus Q551L Battery Replacement, Battery: étape 3, image 2 de 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Battery Replacement: étape 4, image 1 de 2 Asus Q551L Battery Replacement: étape 4, image 2 de 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
4 autres ont terminé cette réparation.
Drew Lawson
Membre depuis le 04/09/18
387 Réputation
2 tutoriels rédigés
Un commentaire
Is there a part to order if the solder gives from the mother board connection peice. My cable came up from the board with connection still attached
wolf brown - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 35
Total : 7,020
