Aller au contenu principal
Asus Q551L Repair Motherboard Replacement
Ce dont vous avez besoin
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: étape 1, image 1 de 2 Asus Q551L Repair Motherboard Replacement, Back Panel: étape 1, image 2 de 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: étape 3, image 1 de 2 Asus Q551L Repair Motherboard Replacement, Battery: étape 3, image 2 de 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: étape 4, image 1 de 2 Asus Q551L Repair Motherboard Replacement: étape 4, image 2 de 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): étape 5, image 1 de 3 Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): étape 5, image 2 de 3 Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): étape 5, image 3 de 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: étape 6, image 1 de 3 Asus Q551L Repair Motherboard Replacement, Motherboard: étape 6, image 2 de 3 Asus Q551L Repair Motherboard Replacement, Motherboard: étape 6, image 3 de 3
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: étape 7, image 1 de 2 Asus Q551L Repair Motherboard Replacement: étape 7, image 2 de 2
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: étape 8, image 1 de 3 Asus Q551L Repair Motherboard Replacement: étape 8, image 2 de 3 Asus Q551L Repair Motherboard Replacement: étape 8, image 3 de 3
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
2 autres ont terminé cette réparation.
Baker
Membre depuis le 01/17/18
300 Réputation
1 tutoriel rédigé
Un commentaire
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 2,398
