Aller au contenu principal
Asus Q551L Screen Replacement
Ce dont vous avez besoin
  1. Asus Q551L Screen Replacement, Back Panel: étape 1, image 1 de 2 Asus Q551L Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Screen Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Screen Replacement, Battery: étape 3, image 1 de 2 Asus Q551L Screen Replacement, Battery: étape 3, image 2 de 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Screen Replacement: étape 4, image 1 de 2 Asus Q551L Screen Replacement: étape 4, image 2 de 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Screen Replacement, Screen: étape 5, image 1 de 2 Asus Q551L Screen Replacement, Screen: étape 5, image 2 de 2
    • Use the metal spudger to gently lift the two plastic squares off the screen.
  6. Asus Q551L Screen Replacement: étape 6, image 1 de 2 Asus Q551L Screen Replacement: étape 6, image 2 de 2
    • Unscrew the two PH0 screws and set them aside.
  7. Asus Q551L Screen Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to pry the front edges of the screen off of the back.
  8. Asus Q551L Screen Replacement: étape 8, image 1 de 1
    • Take off the tapes.
    • Gently pry the LCD from the front frame.
4 autres ont terminé cette réparation.
Colleen Ford
Membre depuis le 04/09/18
327 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 3,102
