Introduction
A quick guide to replacing the motherboard.
Ce dont vous avez besoin
Remove all ten screws on the back of the laptop to remove the cover.
Remove the cover.
Next you will be removing the cpu fan. Begin by removing the nine screws holding it in place.
Now slide the motherboard back toward where the disk drive was, lift up and turn over. You will see a cable connected to the bottom of the board. Pull back on the dark plastic frame and then remove the cable.
Set the old motherboard aside and follow the steps in reverse to install the new one.
