Aller au contenu principal
Asus Q552UB-BHI7T12 Screen Replacement
Ce dont vous avez besoin
  1. Asus Q552UB-BHI7T12 Screen Replacement, Screen: étape 1, image 1 de 2 Asus Q552UB-BHI7T12 Screen Replacement, Screen: étape 1, image 2 de 2
    • Remove the two screw covers by hand or by using the pointed end of a spudger.
  2. Asus Q552UB-BHI7T12 Screen Replacement: étape 2, image 1 de 1
    • Remove both screws with a Phillips head screwdriver.
  3. Asus Q552UB-BHI7T12 Screen Replacement: étape 3, image 1 de 2 Asus Q552UB-BHI7T12 Screen Replacement: étape 3, image 2 de 2
    • Wedge an opening tool between the two halves of the screen.
    • Keep the two latches together and go completely around the screen to release all the latches.
  4. Asus Q552UB-BHI7T12 Screen Replacement: étape 4, image 1 de 2 Asus Q552UB-BHI7T12 Screen Replacement: étape 4, image 2 de 2
    • Separate the two parts of the screen.
  5. Asus Q552UB-BHI7T12 Screen Replacement: étape 5, image 1 de 1
    • Remove any tape that is holding the screen in place.
  6. Asus Q552UB-BHI7T12 Screen Replacement: étape 6, image 1 de 2 Asus Q552UB-BHI7T12 Screen Replacement: étape 6, image 2 de 2
    • Use an opening tool to lift out the screen after all the tape is removed.
    • The screen may be stuck due to any tape or any remaining glue.
  7. Asus Q552UB-BHI7T12 Screen Replacement: étape 7, image 1 de 1
    • Pull the screen horizontally away to remove the last cable attached to the screen.
Follow these instructions in reverse order to reassemble your device.
2 autres ont terminé cette réparation.
Alexander Boettcher
Membre depuis le 09/25/17
657 Réputation
5 tutoriels rédigés
Équipe
2 commentaires
Can you show the connection on motherboard for LCD cable?
Bustelo Pilon - Réponse
Does anyone know where I can get this same model replacement?
Anthony C - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 943
