Aller au contenu principal
Asus R510CA-OB01 Fan Replacement
Ce dont vous avez besoin
  1. Asus R510CA-OB01 Fan  Replacement, Battery: étape 1, image 1 de 3 Asus R510CA-OB01 Fan  Replacement, Battery: étape 1, image 2 de 3 Asus R510CA-OB01 Fan  Replacement, Battery: étape 1, image 3 de 3
    • Locate the two switches that lock the battery.
    • Then, push the right switch outward to unlock it.
  2. Asus R510CA-OB01 Fan  Replacement: étape 2, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 2, image 2 de 2
    • Push the left switch outward and push the battery upward at the same time.
  3. Asus R510CA-OB01 Fan  Replacement: étape 3, image 1 de 1
    • Use a Li-ion battery as a replacement for your battery.
  4. Asus R510CA-OB01 Fan  Replacement, Keyboard and Mousepad: étape 4, image 1 de 1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  5. Asus R510CA-OB01 Fan  Replacement: étape 5, image 1 de 1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  6. Asus R510CA-OB01 Fan  Replacement: étape 6, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 6, image 2 de 2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  7. Asus R510CA-OB01 Fan  Replacement: étape 7, image 1 de 3 Asus R510CA-OB01 Fan  Replacement: étape 7, image 2 de 3 Asus R510CA-OB01 Fan  Replacement: étape 7, image 3 de 3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  8. Asus R510CA-OB01 Fan  Replacement: étape 8, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 8, image 2 de 2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  9. Asus R510CA-OB01 Fan  Replacement: étape 9, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 9, image 2 de 2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  10. Asus R510CA-OB01 Fan  Replacement: étape 10, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 10, image 2 de 2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  11. Asus R510CA-OB01 Fan  Replacement: étape 11, image 1 de 3 Asus R510CA-OB01 Fan  Replacement: étape 11, image 2 de 3 Asus R510CA-OB01 Fan  Replacement: étape 11, image 3 de 3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  12. Asus R510CA-OB01 Fan  Replacement: étape 12, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 12, image 2 de 2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
  13. Asus R510CA-OB01 Fan  Replacement, Optical Drive: étape 13, image 1 de 2 Asus R510CA-OB01 Fan  Replacement, Optical Drive: étape 13, image 2 de 2
    • Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
    • Remove the three 2mm silver screws using a Phillips #000 bit.
    • Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
    • With your hands, gently slide the optical drive out of the laptop.
  14. Asus R510CA-OB01 Fan  Replacement, Motherboard: étape 14, image 1 de 1
    • Remove the seven 5mm screws that are holding both the fan and motherboard in place using a Phillips #1 bit.
  15. Asus R510CA-OB01 Fan  Replacement: étape 15, image 1 de 3 Asus R510CA-OB01 Fan  Replacement: étape 15, image 2 de 3 Asus R510CA-OB01 Fan  Replacement: étape 15, image 3 de 3
    • Disconnect the cables from the motherboard by sliding the cable out of place.
    • Disconnect the cables connecting the fan to the motherboard and laptop by pulling the cable out of place.
  16. Asus R510CA-OB01 Fan  Replacement: étape 16, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 16, image 2 de 2
    • Lift the motherboard on the right side so that it is lifted slightly above the hard drive.
    • Slide the motherboard and fan to the right. Both components should be free from the device.
    • Once the fan and motherboard are free from the device, flip them over and remove the cable connecting both components.
  17. Asus R510CA-OB01 Fan  Replacement: étape 17, image 1 de 2 Asus R510CA-OB01 Fan  Replacement: étape 17, image 2 de 2
    • Remove the four 5mm screws connecting the fan and motherboard using a Phillips #1 bit.
    • Once the screws have been removed, the fan and motherboard should come apart.
  18. Asus R510CA-OB01 Fan  Replacement: étape 18, image 1 de 1
    • The motherboard should now be free from the device .
  19. Asus R510CA-OB01 Fan  Replacement, Fan: étape 19, image 1 de 1
    • The fan should be free from the device and can now be replaced.
Presley England
Membre depuis le 03/25/19
16 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G2, Henning Spring 2019 Membre de l'équipe IUPUI, Team S1-G2, Henning Spring 2019
IUPUI-HENNING-S19S1G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 481
