Aller au contenu principal
Introduction
Replacing the motherboard is generally the last thing anybody does, however, sometimes it is necessary. If you reach this point, then this guide will walk you through the process.
Pièces
Aucune pièce spécifiée.
  1. Locate the locking mechanisms that keep the battery in place and slide them outwards. The right mechanism will lock in place, the left one you will need to hold in place.
    • Locate the locking mechanisms that keep the battery in place and slide them outwards.
    • The right mechanism will lock in place, the left one you will need to hold in place.
  2. Use your right thumb to slide the right side of the battery out, then the left side. Use your right thumb to slide the right side of the battery out, then the left side.
    • Use your right thumb to slide the right side of the battery out, then the left side.
  3. Remove the bottom left and right 12.7mm screws using a  JIS 00 screwdriver. Remove the bottom left and right 12.7mm screws using a  JIS 00 screwdriver.
    • Remove the bottom left and right 12.7mm screws using a JIS 00 screwdriver.
  4. Slide back and remove the protective plating on the back of the laptop.
    • Slide back and remove the protective plating on the back of the laptop.
  5. Again with the JIS 00,  unscrew the three 5.7mm screws holding the hard drive in place. These can be found on small brackets on the four corners of the drive.
    • Again with the JIS 00, unscrew the three 5.7mm screws holding the hard drive in place. These can be found on small brackets on the four corners of the drive.
  6. Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in. Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in. Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in.
    • Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in.
  7. Using the JIS 00 screwdriver, remove the bottom left/right 12.7mm screws located on the back of the laptop. Using the JIS 00 screwdriver, remove the bottom left/right 12.7mm screws located on the back of the laptop.
    • Using the JIS 00 screwdriver, remove the bottom left/right 12.7mm screws located on the back of the laptop.
  8. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  9. Slide and lift off the bottom cover. Slide and lift off the bottom cover.
    • Slide and lift off the bottom cover.
  10. There should be an exposed area located on the right center of the bottom of the revealed compartment. Move the silver brackets holding the RAM to the side. The RAM will pop out of its hold. There should be an exposed area located on the right center of the bottom of the revealed compartment. Move the silver brackets holding the RAM to the side. The RAM will pop out of its hold. There should be an exposed area located on the right center of the bottom of the revealed compartment. Move the silver brackets holding the RAM to the side. The RAM will pop out of its hold.
    • There should be an exposed area located on the right center of the bottom of the revealed compartment. Move the silver brackets holding the RAM to the side. The RAM will pop out of its hold.
  11. Remove the RAM
    • Remove the RAM
  12. With the Battery, Hard Drive, and RAM removed, the laptop should look like this Using the JIS 00 screwdriver, remove the 4.7mm screws that are highlighted, there are two in the battery compartment, two on the outsides of the battery locks, and five around the RAM.
    • With the Battery, Hard Drive, and RAM removed, the laptop should look like this
    • Using the JIS 00 screwdriver, remove the 4.7mm screws that are highlighted, there are two in the battery compartment, two on the outsides of the battery locks, and five around the RAM.
  13. With all screws removed, slide fingers in the crease, separating the keyboard from the bottom of the computer With the laptop opened, as shown in the second picture, the bottom is the keyboard cover, it should be completely detached, take it and set it aside With the laptop opened, as shown in the second picture, the bottom is the keyboard cover, it should be completely detached, take it and set it aside
    • With all screws removed, slide fingers in the crease, separating the keyboard from the bottom of the computer
    • With the laptop opened, as shown in the second picture, the bottom is the keyboard cover, it should be completely detached, take it and set it aside
  14. Flip the laptop over, so it is sitting as   it would if you were using it Using the JIS 00 screwdriver, remove all of the 5.7 mm screws remaining in the motherboard and around the fan
    • Flip the laptop over, so it is sitting as it would if you were using it
    • Using the JIS 00 screwdriver, remove all of the 5.7 mm screws remaining in the motherboard and around the fan
  15. Ensure the screw keeping the disc drive in place is removed, then slide the drive out Ensure the screw keeping the disc drive in place is removed, then slide the drive out
    • Ensure the screw keeping the disc drive in place is removed, then slide the drive out
  16. Disconnect the chip under the fan, connected to the motherboard (you should have removed the screws in step 3) Disconnect the chip under the fan, connected to the motherboard (you should have removed the screws in step 3)
    • Disconnect the chip under the fan, connected to the motherboard (you should have removed the screws in step 3)
  17. Remove the two blue and white ribbons To disconnect them, flip the metal bracket that holds them in To disconnect them, flip the metal bracket that holds them in
    • Remove the two blue and white ribbons
    • To disconnect them, flip the metal bracket that holds them in
  18. Remove the gold wire from its port by pulling back the tape, then slide it up and out Remove the gold wire from its port by pulling back the tape, then slide it up and out Remove the gold wire from its port by pulling back the tape, then slide it up and out
    • Remove the gold wire from its port by pulling back the tape, then slide it up and out
  19. Remove the wires at the top left of the motherboard, they can just be pulled out Remove the wires at the top left of the motherboard, they can just be pulled out Remove the wires at the top left of the motherboard, they can just be pulled out
    • Remove the wires at the top left of the motherboard, they can just be pulled out
  20. To remove the motherboard, stick your fingers through the area where the ram is inserted, lifting it up Then pull out to right at a slightly upwards angle Then pull out to right at a slightly upwards angle
    • To remove the motherboard, stick your fingers through the area where the ram is inserted, lifting it up
    • Then pull out to right at a slightly upwards angle
  21. Some new motherboards are sold with a fan attached, if the replacement you have does not, then you will need to remove the fan from the current motherboard To do this, flip the motherboard over once it is removed from the laptop and remove the screws from the bracket holding it in place and remove it
    • Some new motherboards are sold with a fan attached, if the replacement you have does not, then you will need to remove the fan from the current motherboard
    • To do this, flip the motherboard over once it is removed from the laptop and remove the screws from the bracket holding it in place and remove it
Matthew Diaz
Membre depuis le 15/02/2018
315 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Leahy Spring 2018 Membre de l'équipe USF Tampa, Team S1-G6, Leahy Spring 2018
USFT-LEAHY-S18S1G6
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 206
